Old 26-05-08, 11:27   #1
Default Golf 2 Biturbo de 650 CP
VW Golf 2 isi sfideaza din nou varsta, devenind pacientul ideal pentru "transplantarea" unui motor de Golf R32. Ecuatia cuprinde doua turbine, care pun la treaba 650 de cai putere. Transmisia este una de tip syncro, iar sistemul de franare are discuri de 322 mm. Pretul acestui exemplar de Golf 2 este estimat undeva la 40000 de euro.
ID:	546854   Click image for larger version
ID:	546855   Click image for larger version
ID:	546857   Click image for larger version
ID:	546858   Click image for larger version
ID:	546860   Click image for larger version
ID:	546861   Click image for larger version
ID:	546863   Click image for larger version
Old 26-05-08, 11:36   #2
alpina
Default Re: Golf 2 Biturbo de 650 CP
is curios cum pune pe asfalt atata putere,cred ca i patineaza rotile si pe a 4'a daca i dai ca orbu
alpina is offline   Reply With Quote
Old 26-05-08, 11:40   #3
molady11
molady11's Avatar
Super frumoasa:X:X:X:X
molady11 is offline   Reply With Quote
Old 26-05-08, 11:46   #4
[email protected]
f@n3.18's Avatar
da dc are filtru de aer asa de mare ?
f@n3.18 is offline   Reply With Quote
Old 26-05-08, 11:47   #5
alpina
mama cat e =)) ocupa juma din interior
Old 26-05-08, 11:48   #6
RENAULTts
RENAULTts's Avatar
Ca sa te miri tu!
RENAULTts is offline   Reply With Quote
Old 26-05-08, 12:00   #7
nui scumpa delec...
daca propietarul l-ar vine.. l-asi cumpara.. fara doar si poate
Old 26-05-08, 12:10   #8
adrian_tl30
adrian_tl30's Avatar
cred ca este unu din cele mai puternice golfuri foarte frumos
adrian_tl30 is offline   Reply With Quote
Old 26-05-08, 12:36   #9
ar fi tare sa te incorzi la semafor cu asta si sa le dai fum la toti sa ramana cu gura cascata )
Old 26-05-08, 13:03   #10
bt02ffa
bt02ffa's Avatar
vreau si euuuu:P(cand o sa cresc mai mare)
bt02ffa is offline   Reply With Quote
Old 26-05-08, 13:17   #11
Ozeze
stai la semafor shi daca o turezi sigur rad toti de tine ... da shi cand dai drumu la pedala ce ai mai rade shi tu de ei )
Ozeze is offline   Reply With Quote
Old 26-05-08, 13:39   #12
apache
apache's Avatar
40.000 de euro ar fi suma meritata pentru toata munca depusa ...
e frumos ,mergi cu el pe strada si numai tu in capul tau stii ce zace sub capota.....si probabil vor mai stii bmw-arii astia cu 320d din 2001-2003 care te vor privii cu dispret pana cand ii mananci.
apache is offline   Reply With Quote
Old 26-05-08, 14:07   #13
adrian46
adrian46's Avatar
asta e genu d mashina care s pisha p BMW-uri la semafor...e foarte bine ascunsa puterea un golfuletu asta 2
adrian46 is offline   Reply With Quote
Old 26-05-08, 14:13   #14
SV25MBN
Chevrolet Driver
SV25MBN's Avatar
[CHEVROLET]
Pun pariu ca pe sosea s-ar lua multi de tine si te-ar provoca..si cand le-ai da ceata si-ar inghiti apoi saracii limba de ciuda.
SV25MBN is offline   Reply With Quote
Old 26-05-08, 14:26   #15
lol iti dai seama ce faci cu una daia in bucale sau unde se mai tin curse? )
