Old 24-03-08, 16:21   #1
Default Se vinde D1 USA Vertex Soarer
UN VIS FRUMOS SI FURIOS PENTRU DRIFTERI
Masina de drift a celebrului Takahiro Ueno, D1 USA Vertex Soarer, a fost scoasa la vanzare. JZZ30 Toyota Soarer D1 Special Vertex Ridge 30 Soarer imbina un bodykit Vertex cu veleitatile unei masini GT500. Capota si usile sunt confectionate din fibra de carbon si toate geamurile au fost inlocuite cu Acrylic Windows pentru a fi cat mai usoare. Specificatiile masinii sunt urmatoarele:
Motor
Motor 1.5J, HKS GT-TURBINE To-4Z, intercooler ARC, HKS F-CON V Pro, HKS Metal Gasket t=2.0, HKS VALCON PLUS VCAM KIT Pro 264-degree, HKS EVC V, HKS METAL FLOW, HKS R-Type Oil Cooler, HKS Spark Plugs, radiator ARC, Power Enterprise AF TUNER
Evacuare
Muffler full titan Legerfort, sistem de evacuare HKS, HKS front pipe
Suspensie/Frane/Transmisie/Ambreiaj/Diferential
ORC Twin Plate Clutch, HKS HIPER MAX-D', T-ZERO 6pots Brake Calipers, T-ZERO TYPE-TR Brake Pads, T-Zero Brake Rotors, ATS 2 Way Diff, YANACK Toe Control Arms, IKEYA FORMULA Front Upper arms/Lower arms, IKEYA FORMULA Rear Upper arms/Toe Control Rods/Traction Rods
Exterior
Bara fata Vertex Ridge, praguri Vertex Ridge, bara spate Vertex Ridge, fenders aero fata Vertex Ridge, front bumper canards Vertex Ridge, capota carbon Vertex Dry, usi carbon Vertex Dry, eleron pro SARD GT, sistem HID BELLOF Spark White, geamuri Acrylic HPI, oglinzi Craft Square TC-N1 Touring Competition
Interior
Scaune sport HKS, ceas temperatura ulei/ceas boost HKS, volan MAX RACING MDLM SYSTEM VERTEX (90 mm Deep), roll cage CARBING Chromium-Molybdenum/Adjustable Heel, Plate/Pedal set/Radiator plate, VERTEX Original Harness
Roti/Cauciucuri
Jante RAYS VOLKRACING GT-V: fata 10J - 18 +23, spate 11J - 18 +15, cauciucuri YOKOHAMA ADVAN NEOVA: fata 255/35-18, spate 265/35-18
Alte modificari
KOUEI Body Reinforcement, Rear Fenders wide Processing, All Paint, Special Ordered Front Window, rezervor ATL Safety, Fuel Pump BOSCH
Pret
Nespecificat
ID:	494027   Click image for larger version
ID:	494028   Click image for larger version
ID:	494030   Click image for larger version
ID:	494031   Click image for larger version
Old 24-03-08, 16:39   #2
rhadu
rhadu's Avatar
Default Re: Se vinde D1 USA Vertex Soarer
tare asta ...
de vanzare, iar pretul nespecificat
rhadu is offline   Reply With Quote
Old 24-03-08, 17:30   #3
o sa'i scriu la mosu sa-mi aduca si mie una
Old 24-03-08, 17:57   #4
gunball
gunball's Avatar
hai sa strangem bani sa o luam..si ne dam fiecare cu ea
Old 24-03-08, 20:00   #5
KaPoNe
KaPoNe's Avatar
hai facem cheta fratilor.........yo pun 50 lei noi............)
KaPoNe is offline   Reply With Quote
Old 24-03-08, 20:29   #6
oachy
oachy's Avatar
Imi iau si yo una, da de jucarie
oachy is offline   Reply With Quote
Old 24-03-08, 20:30   #7
B16EZY
Dacia Driver
B16EZY's Avatar
yo cred k e gratis, odata ce nu are pretu specificat
B16EZY is offline   Reply With Quote
Old 24-03-08, 21:43   #8
xtrim
xtrim's Avatar
sunt curios pana la ce suma va ajunge licitatzia
Old 24-03-08, 21:45   #9
momentan am 20.000€
Old 24-03-08, 21:48   #10
CHIRIAC_87
CHIRIAC_87's Avatar
misto masina dar in legatura cu pretu hmm aici e un semn de intrebare.
CHIRIAC_87 is offline   Reply With Quote
Old 24-03-08, 21:58   #11
Mjeefo
Mjeefo's Avatar
Voi nu apreciati deloc masina asta si nici pilotul ei. Masina asta valoreaza enorm, ganditiva ca el sa perfectionat in ea. Pai voi daca primiti masina asta de craciun o sa iesiti cu prietena la disco in ea. Masina asta ori o ea cineva care face ceva cu ea gen Tengu, ori la muzeu, a facut istorie.
Jeefo
Mjeefo is offline   Reply With Quote
Old 24-03-08, 22:34   #12
Ma mir cum pentru aceasta masina ,defapt banii care ii scoate in urma vanzarii de pe masina asta nu sunt folositi in acte de caritate ,dobicei asa se intampla.
Oricum masina asta este un monstru daca se poate spune si un " tocator " de pneuri .
Old 25-03-08, 01:41   #13
FIGHET
FIGHET's Avatar
la asta cu siguranta se sare de suta de mii de euro, frumosi bani pt donatie
FIGHET is offline   Reply With Quote
Old 25-03-08, 08:48   #14
lucian ion
offf ciar asaa taavalio si eu putin dar nu am decat 2500 de E si o dacie as dao la combinatie ,o vrea????????
lucian ion is offline   Reply With Quote
Old 25-03-08, 08:52   #15
adut
OverSpeed Tuning Club Member
adut's Avatar
[Toyota]
[OverSpeed Tuning Club]
hai sa punem toti bani...macar o data sa apukm sa ne dam cu ea
