Old 28-01-08, 11:38   #1
Default Ford Mustang Obsidian Sg-one
Ce ti-ai construi daca ai avea fonduri nelimitate, o dragoste pentru mustangurile clasice si o pasiune pentru hot-roduri? Uita tot ce stiai despre mustangurile clasice fiindca acum vorbim de cu totul altceva.Asa ca o sa va introduc Obsidian SG-One Mustang.
Puternic, elegant si impunator, este unicat. De fapt, este doar unul singur fabricat si nu va fi niciodata reprodus. Asta nu ar trebui sa fie o surpriza.
Date motor:
- Horsepower: 800+HP on pump gas (est) Over 1,000+ HP is possible w/tuning
- Torque: 750 lbs. ft. on pump gas (est)
- 0-60: 4 sec. (est)
- Top Speed: Could possibly be the fastest streetable Mustang ever
- Weight: Approximately 3,000 lbs.
- Length: 190.6
- Obsidian 392 cubic inch engine (351W based), 800+HP on pump gas
- Big Stuff 3 fuel injection w/on-board computer mgt. & in-dash diagnostics
- Rotrex C38-81 twin superchargers & Active twin blow off valves
- Hogan custom aluminum intake manifold w/Viper twin throttle bodies
- Spearco custom twin air to air intercoolers
- Custom billet aluminum pulley system, radiator core support & firewall
- Aeromotive fuel pump & custom alum. fuel tank (sumped & baffled)
- Doug Thorley custom headers, custom dual exhaust & aluminum tips
- Tremec TKO 600 5-speed manual w/Master Shift paddle shifters
- Mittler Brothers 9" fabricated rear end housing w/Currie 31-spline axles
Date sasiu:
- Integrated tubular chassis, 4-point hidden roll cage & 4-piece belly pan
- Redesigned shock towers, rear frame rails, reinforced frame rails & jack pads
- Lowered center of gravity (for high speed stability & aggressive look)
- Engine & firewall have been pushed back (for better weight distribution
Date suspensie:
RRS Phase 5 front coil over suspension (Koni shocks w/Eibach springs)
- RRS rear 3-link coil over suspension w/torque Arm
- Brembo 14" 4-wheel disc brakes w/4-piston calipers
- RRS power rack & pinion steering w/IDIDIT brushed tilt steering
- Power Brake Service hydroboost power brakes
Date interior:
- 2-seat conversion w/seats/boxes pushed back (for a modern sports car feel)
- Recaro custom ultra heated leather seats w/full lumbar support
- 4-point safety harness system
- Luxury carpeting, sound proofing & heat insulation
- Electronic A/C, Electric Life power windows, door locks & 3-speed wipers
- Kicker 3,000 watt sound system w/5.1 Dolby digital surround sound
- DVD GPS Navigation, XM Radio, MP3, WMA, iPod, Bluetooth, 60 Gig hard drive, Mobile Wi-Fi Internet, HomeLink & more
- 10.5" LCD touch screen monitor (operates electronics for vehicle)
- Keyless ignition, remote keyless entry & vehicle security system
- Stewart Warner gauges w/chameleon light package
- Hand crafted color matched dash board extends several inches over stock
- Hand crafted 2-piece door panels, headliner, center console & rear panels
- Leather wrapped billet steering wheel w/manual paddle shifters
- Lokar billet pedals & various billet accessories
SURSA: FORD PRESS
ID:	436777   Click image for larger version
ID:	436778   Click image for larger version
ID:	436780   Click image for larger version
ID:	436781   Click image for larger version
like my fb page
Old 28-01-08, 12:48   #2
Ingerasul99
Ingerasul99's Avatar
Default Re: Ford Mustang Obsidian Sg-one
super tare
Ingerasul99 is offline   Reply With Quote
Old 28-01-08, 13:18   #3
boy_wonder
boy_wonder's Avatar
deocamdata este unicat doar poate fi reprodus contra sumei de $1.3M..
Old 28-01-08, 13:31   #4
Ionutz maniacu
No comment.Nu ii poti reprosa nimic nici ca aspect nici ca performante.
Ionutz maniacu is offline   Reply With Quote
Old 28-01-08, 13:39   #5
ionutz gresesti unpic ......spoilaru din fatza e chiar urat....dar daca te gandesti la masinutza nu mai conteaza
Old 28-01-08, 14:13   #6
mihai88
mihai88's Avatar
cat de bine a putut sa iasa bordu,exterioru,interioru...totu ce sa..................putere cat cuprinde,muzica la fel...nu ca ai avea nevoie la asa piesa,numai piese de calitate
nota 10++++
(o singura intrebare 3000 lbs=cate kg?1500?)
mihai88 is offline   Reply With Quote
Old 28-01-08, 14:22   #7
boy_wonder
boy_wonder's Avatar
mai exact..
3 000 pounds = 1 360.77711 kilograms
Old 28-01-08, 14:53   #8
Cat de bine arata spatele,motorul si interiorul.. o masina de 10* superba
Old 28-01-08, 15:00   #9
aldoadabass_wrs
aldoadabass_wrs's Avatar
ft tare faza cu diferentiau intre scaune....ma gandesc k ii cam zgomots....shi cam nasol dak pusca....te aschiaza in masina.....in rest....the best...sant fan hot rod de cand ma stiu....dar nu e suprema hot rod-urilor....event. da best mutang:d
aldoadabass_wrs is offline   Reply With Quote
Old 28-01-08, 15:07   #10
parerea mea e ca interiorul a iesit cel mai bine la mustangul asta
Old 28-01-08, 15:19   #11
pfuuuuu......daca as fi castigat la lotto as fi alocat 10% pt masina asta incredibila
Old 28-01-08, 15:32   #12
absolut superb... moartea mea
Old 28-01-08, 16:07   #13
dragos002
dragos002's Avatar
Phiuu o adevarata bijuterie... si unicata
dragos002 is offline   Reply With Quote
Old 28-01-08, 16:30   #14
UNLORD
UNLORD's Avatar
Masina arata mai bine decat in pozele postate aici :
http://www.autobild.de/mmg/mm_bildergalerie_524556.html
Old 28-01-08, 18:16   #15
Sindrom
Sindrom's Avatar
DRAC...dracos....
Sindrom is offline   Reply With Quote
