Go Back   Forum 4Tuning > MOTORSPORT > WRC - FORMULA 1 - Alte sporturi cu motor
Old 11-01-08, 12:25   #1
Default Aston Martin Lupta pentru titlu
Aston Martin Racing se intoarce anul acesta laLe Mans pentru a-si apara titul GT1in cursa de anduranta de 24h in fata adversarului sau Corvette Racing.
In cursa se anunta participarea a 2 modele Aston Martin DBR9 in culorile traditionale Gulf Oil (albastru si portocaliu). Masinile vor purta numerele -007- si -009-.
De la James Bond vine 007 probabil, dar 009 de la ce?
ID:	423479   Click image for larger version
Old 11-01-08, 12:36   #2
meleboss4u
meleboss4u's Avatar
Default Re: Aston Martin Lupta pentru titlu
sa speram ca o sa castige. numerele masinilor sunt cele mai tari
meleboss4u is offline   Reply With Quote
Old 11-01-08, 16:42   #3
UNLORD
UNLORD's Avatar
Arata f. bine masinutza!
Old 09-03-08, 16:44   #4
F.E.A.R
F.E.A.R's Avatar
superba... eu tin cu ei
Old 14-03-08, 20:39   #5
cristi.a
cristi.a's Avatar
Pai de la DBR9 vine 009.
Gulf oil a declarat ca anul asta castiga. Sarbatorim 40 ani de la victoria de la Le Mans (1968/69/75), deci trebuie sa castigam. In '68 a fost legendarul GT 40. In '69 a fost Porche.
Si iata cateva cifre despre DBR9
Engine
All alloy, quad overhead camshaft, 48-valve, V12 Aston Martin Racing engine.
Capacity: 6 litres
Power: 600 bhp
Torque: 700 Nm
Transmission
Xtrac, six-speed sequential transmission longitudinally mounted at the rear axle. Four plate carbon clutch.
Structure
Race-developed DB9 aluminium chassis with high strength steel roll-cage. Body panels in carbon fibre composite excluding the aluminium roof.
Suspension
Double wishbone suspension front and rear with adjustable Koni dampers and Eibach springs.
Brakes
Front and rear: Six-pot calipers with 330 mm diameter carbon discs.
Wheels
Front and rear: Forged magnesium 18"..
Dimensions
Length: 4,687 mm + 80 mm
Width: 1,978 mm
Height: 1,195 mm
Wheelbase: 2,741 mm
Weight: 1,100 kg
Cu respect,
cristi.a
Director General Gulf Romania
cristi.a is offline   Reply With Quote
