Go Back   Forum 4Tuning > www.4tuning.ro > ARHIVA > Arhiva evenimente > 4Tuning VT contest 2006
Old 10-01-07, 03:07   #1
ZoliaT
ZoliaT's Avatar
Thumbs up "4Tuning VT Contest" Decembrie 2006 - Lucrari 2d
"4Tuning Contest" Decembrie 2006 - Lucrari 2d
Ultima poza din post = original, masina care a trebuit modificata virtual, Dacia Logan MCV.
ID:	211266   Click image for larger version
ID:	211267   Click image for larger version
ID:	211269   Click image for larger version
ID:	211270   Click image for larger version
ID:	211272   Click image for larger version
ID:	211273   Click image for larger version
ID:	211275   Click image for larger version
ID:	211276   Click image for larger version
ID:	211278   Click image for larger version
ID:	211279   Click image for larger version
ID:	211281   Click image for larger version
ID:	211282   Click image for larger version
ID:	211284   Click image for larger version
ID:	211285   Click image for larger version
ID:	211287   Click image for larger version
ID:	211288   Click image for larger version
ID:	211290   Click image for larger version
ID:	211291   Click image for larger version
ID:	211293   Click image for larger version
ID:	211294   Click image for larger version
ID:	211296   Click image for larger version
ID:	211297   Click image for larger version
ID:	211299   Click image for larger version
Name:	logan break.jpg
ZoliaT is offline   Reply With Quote
Old 19-01-07, 01:24   #2
Gratzian
Gratzian's Avatar
Default Re: "4Tuning Contest" de Sarbatori - Lucrari 2d
LOCUL I = ad1
Creativitate 8/10
Atentie la detalii 8/10
Finisaje 8/10
Ansamblu 9.5/10
Cu toate ca la o prima vedere nu pare nimic impresionant, finetea se afla in detalii.
Multe din modificarile estetice aduse ar trebui sa-i puna pe ganduri pe designerii de la Dacia.
Dupa modificarile aduse, masina devine mai armonioasa, pierzand mult din aerul de ieftin
emanat de unele detalii originale. Aceasta lucrare se afla mult peste altele din punct de vedere
al atentiei la detalii, mare pacat insa de stickere si scrisul de pe cauciucuri care se afla in
contrast cu modificarile subtile ale caroseriei, fara acestea fiind mai putin atragatoare la
prima privire insa mai reusita ca un tot unitar.
Ce ne-a placut:
Masina a fost coborata frumos
Al 3-lea rand de scaune scos bine
Oglinzi, ambele schimbate
Ce nu prea:
Kit-ul nu "curge"
Stopurile
Bara fata aduce putin a Ford Focus
Aceeasi umbra dupa coborare
Gratzian is offline   Reply With Quote
Old 19-01-07, 01:39   #3
Gratzian
Gratzian's Avatar
021 - LOCUL II = OmB*
Creativitate 10/10
Atentie la detalii 7/10
Finisaje 7/10
Ansamblu 9/10
Fara o lucrare cu adevarat impresionanta din totate punctele de vedere, decizia pentru locul 2 s-a facut bazat pe creativitate si inedit. Si conceptul cu numarul 21 le are din plin. Incredibil de reusita armonia intre agresivitatea si masivitatea de origine americana si liniile Logan-ului nostru relativ cuminte din nastere. Un exercitiu de tuning virtual cu rezultate de concept putin fu*urist, ar putea fi cheia succesului marcii Dacia pe continentul Nord American.
Lucrarea nu este totusi lipsita de greseli si finisaje defectuase, ca un mic exemplu ar fi fundalul vizibil la janta din fata, lucru imposibil in realitate datorita perspectivei.
Ce ne-a placut:
Integritatea elementelor adaugate
Luminile galbene din semnalizare tipic americane
Ce nu ne-a placut:
Roti spate de latime diferita, idem fata
O singura oglinda schimbata
Cauciuc prea subtire in spate
Old 19-01-07, 02:01   #4
Gratzian
Gratzian's Avatar
012 - LOCUL III = criss
Creativitate 8/10
Atentie la detalii 9/10
Finisaje 8/10
Ansamblu 8.5/10
Pe locul trei avem o lucrare foarte bine realizata pana a fost stricata inexplicabil prin aplicarea mult prea puternica si total defectuasa a reflexiilor. Sunt de apreciat unele detalii aprofundate, fiind evident timpul si atentia acordata. Cu ceva mai multa atentie aceasta lucrare se putea clasa mai bine. Oricum, o combinatie reusita de lucrare buna atat in partea de detalii si realizare cat si de originalitate. Ii dam bonus o oglinda sa studieze fenomenul fizic al reflexiilor.
Ce ne-a placut:
Kit-ul uniform
Ideea spatelui descoperit
Umbra la coborarea masinii
Ce nu ne-a placut:
Reflexii, lumini si umbre
Old 19-01-07, 02:43   #5
Gratzian
Gratzian's Avatar
025 - mentiune = Yackone
Creativitate 8/10
Finisaje 7/10
Ansamblu 8.5/10
Lucrarea se defineste printr-un exterior interesant si destul de omogen, iar coloristica este deosebit de reusita, fiind totusi cunoscuta ca o combinatie two-tone foarte buna de ceva vreme. Deranjeaza totusi spotul de lumina care intra in contrast cu luminozitatea generala a masinii si a fundalului cat si artifactele generate de exagerarea prelucrarii coloristice a suprafetelor. De asemenea elemente cum ar fi jantele sau partea ne-editata a pragurilor au fost originate din poze de rezolutie inferioara, astfel ajungand sa fie prea "in ceata".
Old 19-01-07, 03:21   #6
Gratzian
Gratzian's Avatar
027 - PREMIU SPECIAL = P.I.M.P. Boy
Creativitate 10/10
Finisaje 7/10
Ansamblu X/10
Din nefericire nu ar fi corect sa comparam aceasta lucrare cu celelalte, se afla in complet alta zona (nu prea aproape de terra ar zice unii) insa in acelasi timp nu putem sa nu apreciem munca si idea din spatele ei.
Un mic freehand digital cu design organic. Ca sugestii de viitor, reflexiile au in general rostul de a defini materialul, deci trebuiesc sa fie consecvente din toate punctele de vedere, pe toata suprafata.
Name:	premiul special.jpg
