Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Alte Anunturi Piese
Old 08-11-06, 16:45   #1
BMW70ANGELAYES
BMW70ANGELAYES's Avatar
Default piese bmw ,motoare 2,2.5,3.0,3.5,orce piesa
PIESE E30 (URS) E36 (PISICA) E32( 7-AR )E34 (5-AR)
USI ,ARIPI,CAPOTE ,ELEM DIRECTIE
-MOTOR 2000 12valve complet 400e
-MOTOR 2500 12valve complet 400e
-MOTOR 3000 12VALVE COMPLET 400E
-MOTOR 3500 12 VALVE COMLET 400E
-SET ROTI IARNA 5X120 195/65/15 SAU 205/60/15 4 MIL SET 4 BUC
-bloc motor complet echipat M52 24V 150 cai 2.0 L PRET DISC
-BAIE ULEI BMW E36(SERIA 3 90-9 E39(96-2004) 100E disc
-INSTALATIE ELECTRICA 1 mil urs/BUTON A/C 500 MII/BUTON REGLAJ BOXE 500 MII
-set 4 plastice contraripi urs 1 mil(aparatorile de noroi de sub aripa)
-saxofon galerie 1.6/1.8 500,ETRIERI URS PT FATA ST ,DR DOAR SET 1 MIL(COMPLET)
-BORD (COAJA)1 MIL URS(CRAPAT),ELECTROMOTOR 3MIL ,MANETA FRANA 500 MII,SUPORT FRANA MANA (PLASTIC) 300 MII
-MANETA electrica de STERGATOR 500 mii URS URS
-SET ORNAMENTE DE USI +GEAMURI LATERALE SPATE URS 300 MII BUC
-1 BUC PORTIERA USA PARTEA DIN DREAPTA (PT URS IN 2 USI)500 MII BUC
-capota(PORTBAGAJ) URSULET 500 mii
-MACARA GEAM mecanica 500 MII URS ST DR 2 BUCATI.faza scurta cu lupa 1 mil buc
-POMPA BENZINA BOSH DE INALTA PRESIUNE (afara din rezervor)2 MIL PT ORCE auto
-POMPA SUMERSIBILA IN REZERVOR DE BMW 3 MIL indicator benzina (in rezervor)500 m
-GEAMURI LATERALE st /dr ,GEAM LUNETA CU DEZABURIRE 500 MII bucata URS 2 usi
-SET BANDOURI 1 MIL URS+bandou bara spate+bandou bara fata(de la bara din fier)
-MOTOR STERGATOR PARBRIZ bmw 500 MII
-VOLAN SPORT 1.500.000 URS 3 SPITE MOMO cu tot cu butuc SH ,butuc 500 mii
-RAMA (MASCA)FAR 300 MII /buc t dr
-CARBURATOARE PIERBURG WEBBER 1.000.000 BUC AM SI UNUL DE DACIE CU 500 MII
***************PT E 34 ,e39 5-ar ,e36 pisica 3-ar E 30 E32 7 AR *******
-2 proiectoare bosh e36 seria 3 pisica 2 .5 mil set impecabile
-set 2 buc stopuri tuning pisica cupe 2 usi 2 mil noi
-2 anv iarna continental carne 90% 195/65/15 1 mil buc
-CALCULATOR A.B.S cod:0265100049 1.5 MIL.,USITA REZERVOR E34 500 MII (culoare neagra)
-CALCULATOR BOSH MOTRONIC 3.5 MIL cod 0261200386 M40 MOTOR 1800 CM 120 CAI
-POMPA SUMERSIBILA (IN REZERVOR )BMW 3 MIL URS PISIC 5-AR
-POMPA BENZINA BOSH DE INALTA PRESIUNE 2 MIL AFARA DIN REZERVOR URS SAU ORCE MASINA
-bloc lumini e34 poz, faza scurta +relaj lumina bord 100 lei
-buton asc e34 30 lei
-buton suspensie hidraulica e34 sport sau confort 30 lei
-VOLAN SERIA 5 E 34 1 MIL IMBRACAT PIELE de serie (ALA IN 4 SPITE)CLASSIC
-BASCULE E34 SERIE 5 ST DR 1.MIL BUC SUPORT MOTOR DIN ALUMINIU 1136537/1135948
-BARA STABILIZARE 1.MIL, CAP BARA DR e39(nou 800 mii)
-role intinzatoare curea alternator +amortizor 500 mii buc
-ELECTROMOTOR BOSH (pt curea lata 24 v)0001108065 3.5 MIL
-INSTALATIE ELECTRICA PT BORD E 34+INSTALATIE OBC 2 1 MIL
-semnale galbene originale e 34 sr/dr 500 MII set sau 250 mii buc
-senzor temperatura cel din bara care indica temp exterioara 1 mil merge pe
orce bmw, STOP DR 5-ar E 34 1 MIL
-SET INJECTOARE +RAMPA INJECTOARE 24 V +GALERIE ADMISIE COMPLETAplastic 3.5 mil
SAU PE BUC INJECTOARE 500 MII BUC(daca luati mai multe pret disc)
-REGULATOR RELANTI BOSH 1 MIL
- FISE BUJI (bobine) -FISE 24VALVE-500.000 BUC CU PROBA
- AxA CAME PT 2.0/2.5 24VALVE 3.5 mil bucata CA NOI ,FARA GRAD DE UZURA
-set TACHETI HIDRAULICI 12 x2 3 mil setul ,SUPORT(ALUMINIU)+FILTRU ULEI 1 MIL
-CHIULOASA 24 v m50
-timonerie e34 +maneta cutie viteza 100 lei
-SUPAPE PT CHIULOASA 250 mii bucata ,SONDA APA 500 MII ,SENZORI VOLANTA 1 MIL
FATA(CITITOR ),SONDA LANDA 1.5 MIL,SENZOR TEMPERATURA EXTERN (PT BARA )1 MIL
-1 VIBROCHEN 520 24v m50 FARA REPARATIE COTA 0 (130.000 KM REALI )FARA GRAD DE UZURA +cuzineti biela si palier 24 v 520 5 mil
-6 PISTOANE+segmenti 2000 cm 24 v m50 cod mhale 80 V197 3 MIL BUC
-6 pistoane +segmenti+bloc+cuzineti+baie+vibrochen 2.0 24v M52 an 98 vanos (sau mai pe scurt motor complet fara chiuloasa pret 250e
-POMPA ULEI 2 MIL cod 1726665, BAIE ULEI ALUMINIU 520/525 24 v 3 MIL
-SAXOFON 24V M50 M30 500 MII BUCATA TIMONERIE CUTIE 500 MII
-capac cotiera bmw e39 500 mii pe gri
- CAPAT DE BARA E39 sr sau dr 1MIL nou
- CASETA DIR E39 buna 500e
- POMPA SERVO DIR E39 2.000.000
- Geam oglinda e39 100 lei
-ORNAMENTE MAHON PT USI E39 posibil si e34 100 LEI
-motor complet fara chiuloasa 250e M52 2.0 24 V SAU PE BUCATI
-FARURI E 39 MATE 2 MIL SEMNAL GALBEN
BMW70ANGELAYES is offline
Old 08-11-06, 16:50   #2
Adi_UZI
Adi_UZI's Avatar
Default Re: piese bmw ,motoare 2,2.5,3.0,3.5,orce piesa
instalatia electrica de urs e de 4 usi??
Adi_UZI is offline
Old 08-11-06, 16:53   #3
BMW70ANGELAYES
2 dar daca e gasim si pt 4 lasa nr
Old 08-11-06, 20:22   #4
shadow
Presedinte AfterDark Racing
shadow's Avatar
[AfterDark Racing]
[Honda]
M-ar interesa si pe mine 2 scaune in stare buna.
Poti sa imi lasi si mie un nr de tel.
shadow is offline
Old 08-11-06, 21:12   #5
heavystorm2005
heavystorm2005's Avatar
pentru pisica gasim un motor +cutie complet de 20 sau 2.5?la ce pret?
heavystorm2005 is offline
Old 09-11-06, 07:37   #6
Sorin Golf 3 cabrio
Salutare, ma intereseaza si pe mine de la motorul 2.5 injectorul 7 (cel de soc).
Sorin Golf 3 cabrio is offline
Old 09-11-06, 12:45   #7
Simpaticutzu'
Simpaticutzu''s Avatar
Sal! Ma intereseaza si pe mine pt URS in 2 usi din '84, bandourile de pe partea stanga(portiera+aripa spate), ca aripa fata am. Tel. 0721.292.624. Accept bip si sun eu inapoi. Multumesc.
Simpaticutzu' is offline
Old 10-11-06, 12:35   #8
doxas
-CHIULOASA 24 v m50
spune-mi te rog cum pot lua legatura cu tine pt un carburator de E30
doxas is offline
Old 10-11-06, 12:37   #9
doxas
m-ar interesa un pierburg webber
doxas is offline
Old 30-04-07, 15:24   #10
solomonien
sal, doresc sa cumpar bandou usa dreapta, E34
solomonien is offline
Old 20-05-07, 23:54   #11
YZF-PWR
YZF-PWR's Avatar
[X-Team Racing Club]
[Honda]
[Mitsubishi]
Salut , instalatia electrica pt un urs in 2 usi , ATENTIE motorul 18 IS si neaparat sonda landa pt acel motor daca ai! te rog sa imi dai un raspuns cand ai timp si lasa aici un nr de telefon sau da-mi un mesaj pe privat. mersi . bafta
Liga Moderatorilor
YZF-PWR is offline
Old 27-05-07, 15:50   #12
BMW70ANGELAYES
e 1,8 carburator ..........
-volan multi functional(comenzi cd,asc ...)imbracat in piele cu airbag 500e http://www.realoem.com/bmw/showparts...63&hg=32&fg=35
-volan fara airbag 4 spite in piele 300 lei
-capac cotiera bmw e39 100 LEI (pe gri) http://www.realoem.com/bmw/showparts...66&hg=51&fg=35
-ORNAMENTE MAHON PT 4 USI E39 posibil si e34 100 LEI
-stopuri e39 70e http://www.realoem.com/bmw/showparts...06&hg=63&fg=20
_lucasuri aripa 1mil http://www.realoem.com/bmw/showparts...03&hg=63&fg=10
_lampa luneta 50 lei http://www.realoem.com/bmw/showparts...05&hg=63&fg=25
-lampi interior 50 lei http://www.realoem.com/bmw/showparts...07&hg=63&fg=30
-fulie pompa de apa 2.0/2.5 24v 50 lei
-jante magneziu in spite + 15 http://www.realoem.com/bmw/showparts...18&hg=36&fg=15 300e
-fulie A/C 2.0/2,5 100 lei (cea cate vine in centru la volanta din fata)
-compresor A/C 250E http://www.realoem.com/bmw/showparts...80&hg=64&fg=50
-timonerie cutie e39 50e
-antifurt roti 50e http://www.realoem.com/bmw/showparts...13&hg=36&fg=25
-maneta schimbator +aparatoare 50e
http://www.realoem.com/bmw/showparts...10&hg=25&fg=10
-piese cutie diesel 524/525 tds e34 e39(cutie intreaga desfacuta )50e http://www.realoem.com/bmw/partgrp.d...43&hg=23&fg=15
-pompa ambreaj 100 LEI
-pedalier seria 5 e39 e34 150E http://www.realoem.com/bmw/showparts...66&hg=35&fg=05
_calculator pt acceleratie 50e http://www.realoem.com/bmw/showparts...71&hg=35&fg=15
-cal pt cutie manuala e39 100e http://www.realoem.com/bmw/showparts...64&hg=51&fg=35
-disc ambreaj 2 mil http://www.realoem.com/bmw/showparts...20&hg=21&fg=05
-grup e39 520 /520 d an 2002 300e http://www.realoem.com/bmw/showparts...41&hg=33&fg=05
-bascula spate st e39 150e http://www.realoem.com/bmw/showparts...19&hg=33&fg=30
-planetare e39 100e http://www.realoem.com/bmw/showparts...22&hg=33&fg=25
-usita rezervor e39 100 lei
elemente caroserie (plafon +stalpi 500e, prag st 200e,aripa spate st 300e, oale lonjeroane fata ,spate ) http://www.realoem.com/bmw/showparts...47&hg=41&fg=05
-stalip 100e ,plafon 500e ,
-contraaripa +oale 100e
-lonjeroane 150e http://www.realoem.com/bmw/showparts...49&hg=41&fg=10
--aeroterma a/c e39 200e
-piesa tepi aeroterma 150 lei
-calculator abs 100e
-calculator inchidere (confort ) 50e
-calculator airbag 100e
-CENTURI FATA SPATE 1mil buc http://www.realoem.com/bmw/showparts...11&hg=72&fg=05
-usi PARTE STANGA FATA /SPATE e39 250e
-luneta 70e cu dezaburire si antena radio
http://www.realoem.com/bmw/showparts...49&hg=51&fg=05
-geamuri laterala 70e SPATE http://www.realoem.com/bmw/showparts...48&hg=51&fg=05
-coltar geam dreapta spate 1mil http://www.realoem.com/bmw/showparts...48&hg=51&fg=05
-set macarale electrice spate 250e+butoane http://www.realoem.com/bmw/showparts...51&hg=51&fg=10
-set macarale electrice fata 250e http://www.realoem.com/bmw/showparts...50&hg=51&fg=10
-geamuri (OGLINZI) E39 30e buc http://www.realoem.com/bmw/showparts...87&hg=51&fg=10
-CARCASA oglinda +geam heliomat 100e http://www.realoem.com/bmw/showparts...64&hg=51&fg=10
-torpedou 50e http://www.realoem.com/bmw/showparts...76&hg=51&fg=30
-coaja bord 100e capac airbag 1mil http://www.realoem.com/bmw/showparts...18&hg=51&fg=30
-sistem audio bmw bisniss :2 boxe fata (bass)+2 boxe spate (bass)+inalte+medii+incinte+filtre ... firma nokia originale bmw putere 40w pret total 50e
-electromotor bosh benzina 150e http://www.realoem.com/bmw/showparts...01&hg=12&fg=25
-baie ulei e39 pt benzina 100e
-pompa frana e39 100e
-electromotor benzina e39 150e
-cap bara st -dr .e39 800 mii
-buton asc e39 50 lei
-buton avarie e39 50lei
-buton inchidere usi e39 50 lei
-panou comanda 4 geamuri +oglinzi (cel de pe usa soferului )70e
-panou comanda A/C 50 E http://www.realoem.com/bmw/showparts...47&hg=64&fg=20
-scrumiera 100 LEI http://www.realoem.com/bmw/showparts...64&hg=51&fg=35
-tamburi frana mana set st dr 4 buc 1,5 mil http://www.realoem.com/bmw/showparts...73&hg=34&fg=30
-maneta frana mana 50e http://www.realoem.com/bmw/showparts...39&hg=34&fg=30
-tulumba+ pompa frana 100e http://www.realoem.com/bmw/showparts...47&hg=34&fg=25
-pompa frana 50e http://www.realoem.com/bmw/showparts...28&hg=34&fg=25
-etrieri e39 50e st/dr http://www.realoem.com/bmw/showparts...36&hg=34&fg=10
-discuri e39 2 bucati 3 mil http://www.realoem.com/bmw/showparts...36&hg=34&fg=10
-rulment roata +fuzeta 2 mil http://www.realoem.com/bmw/showparts...83&hg=33&fg=40
-senzor ABS spate 2 mil http://www.realoem.com/bmw/showparts...47543&btnr=33_
carlig remorca 100e
senzor prezenta scaun pasager dr 2 mil
senzor centura 2 mil
maciulie viteze 50 lei
manere interior deschidere usa 1 mil buc
maner exterior deschidere usa 1.5 mil buc
motoras usa 50 lei
ecran 16:9(doar ecranul )200e
ecran 4:3 100e
proiector facelift dr 150 lei
bara fata e39 gauri pt proiectoare mari 100e verde inchis
set bandouri negre 100e
bloc m52 vanos pistoane vibrochen
0723515609
Old 27-05-07, 20:52   #13
meddocspeed
meddocspeed's Avatar
salut .. un debimetru pt 2.5 pisicuta gasesc la tine? daca da la ce pret?
meddocspeed is offline
Old 01-06-07, 15:29   #14
bebe no1
bebe no1's Avatar
salut o cutie pentru un 2.5 m20 ai? si la ce bani ms
bebe no1 is offline
Old 02-06-07, 00:29   #15
BMW70ANGELAYES
0724395872 incearca sa suni ......dar cred sa e plecat si il are inchis ....................luni marti pote vine in tara .......
