Go Back   Forum 4Tuning > Masini & Tuning > VERSUS AUTO
VERSUS AUTO SUPRA vs SUBARU, Mercedes vs Bmw, pilotul x vs pilotul y. Aceasta rubrica este dedicata provocarilor,analizelor,pariurilor(virtuale bineinteles),comparatiilor. Rog moderatorii sa fie foarte duri pe acest subiect. Fara OFF-TOPIC
Old 26-08-06, 18:04   #1
b_gt
b_gt's Avatar
Default Aston Martin Vanquish S vs. Lamborghini Murcielago LP640 vs. Ferrari 599 GTB
astept sa vad ce alegeti.....
ID:	142530   Click image for larger version
ID:	142531   Click image for larger version
Name:	bild2006041916064733___AstonMartin Vanquish S.jpg
ID:	142533   Click image for larger version
ID:	142534   Click image for larger version
ID:	142536   Click image for larger version
ID:	142537   Click image for larger version
b_gt is offline   Reply With Quote
Old 26-08-06, 18:06   #2
b_gt
b_gt's Avatar
Default Re: Aston Martin Vanquish S VS Lamborghini Murcielago LP640 VS Ferrari 599 gtb
engine Aluminum Alloy, V12
valvetrain DOHC 4 Valves / Cyl
fuel feed Fuel Injection
displacement 5935 cc / 362.2 cu in
bore 89 mm / 3.5 in
stroke 79.5 mm / 3.13 in
compression 10.5:1
power 387.8 kw / 520 bhp @ 7000 rpm
hp per litre 87.62 bhp per litre
bhp/weight 277.33 bhp per weight
torque 577 nm / 425.6 ft lbs @ 5800 rpm
drive wheels RWD w/LSD
body / frame Aluminum & Carbon Fibre
front brakes Vented Discs w/6-Piston Calipers
f brake size 378 mm / 14.9 in
rear brakes Vented Discs w/4-Piston Calipers
r brake size 330 mm / 13.0 in
front wheels F 22.9 x 48.3 cm / 9.0 x 19.0 in
rear wheels R 48.3 x 25.4 cm / 19.0 x 10.0 in
front tire size 255/40ZR19
rear tire size 285/40ZR19
steering Rack & Pinion w/Variable Power Assist
f suspension Double Wishbones w/Coil Springs, Gas Dampers, Anti-Roll Bar
r suspension Double Wishbones w/Coil Springs, Gas Dampers, Anti-Roll Bar
weight 1875 kg / 4134 lbs
wheelbase 2690 mm / 105.9 in
length 4665 mm / 183.7 in
width 1932 mm / 76.1 in
height 1318 mm / 51.9 in
transmission 6-Speed Manual w/Paddle Shifting
top speed 323.5 kph / 201.0 mph
0 - 60 mph 4.7 seconds
Old 26-08-06, 18:07   #3
b_gt
b_gt's Avatar
engine 60 Degree, Aluminum Alloy, V12
position Mid Longitudinal
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl w/VVT & VIS
displacement 6496 cc / 396.4 cu in
bore 88 mm / 3.46 in
stroke 86.8 mm / 3.42 in
compression 11.0:1
power 477.3 kw / 640 bhp @ 8000 rpm
hp per litre 98.52 bhp per litre
torque 660 nm / 486.8 ft lbs @ 6000 rpm
drive wheels Permanent 4WD w/Viscous Traction
body / frame Carbon Fibre Body over Tubular Steel Frame w/Steel Roof
front brakes Carbon-Ceramic Discs w/Power Assist, 8-Pot Calipers, ABS, DRP
f brake size 380 mm / 15.0 in
rear brakes Carbon-Ceramic Discs w/Power Assist, 4-Pot Calipers, ABS, DRP
r brake size 355 mm / 14.0 in
front wheels F 45.7 x 21.6 cm / 18.0 x 8.5 in
rear wheels R 45.7 x 33.0 cm / 18.0 x 13.0 in
front tire size Pirelli P Zero ROSSO 245/35ZR18
rear tire size Pirelli P Zero ROSSO 335/30ZR18
steering Rack & Pinion w/Power Assist
wheelbase 2665 mm / 104.9 in
front track 1635 mm / 64.4 in
rear track 1695 mm / 66.7 in
length 4610 mm / 181.5 in
width 2058 mm / 81.0 in
height 1135 mm / 44.7 in
gear ratios 3.091:1, 2.105:1, 1.565:1, 1.241:1, 1.065:1, 0.939:1
final drive 2.53:1
top speed 321.9 kph / 200 mph
Old 26-08-06, 18:07   #4
b_gt
b_gt's Avatar
Ferrari 599 GTB
engine Aluminum Alloy V12
position 65 Degree V12
aspiration Natural
fuel feed Multi-Point Fuel Injection
displacement 5999 cc / 366.1 cu in
bore 91.95 mm / 3.62 in
stroke 75.18 mm / 2.96 in
compression 11.2:1
power 455.6 kw / 611 bhp @ 7600 rpm
hp per litre Not Available litre
bhp/weight 361.97 bhp per tonne
torque 607.41 nm / 448 ft lbs @ 5600 rpm
redline 8400
drive wheels RWD w/F1-Trac Stability Control
front brakes Opt Carbon Ceramic Discs
f brake size 353 mm / 13.9 in
rear brakes Opt Carbon Ceramic Discs
r brake size 328 mm / 12.9 in
front tire size 245/40 19
rear tire size 305/35 20
f suspension Double Wishbones w/Delphi Magnetorheological Dampers, Coil Springs, Anti-Roll Bar
r suspension Double Wishbones w/Delphi Magnetorheological Dampers, Coil Springs, Anti-Roll Bar
weight 1688 kg / 3722 lbs
wheelbase 2751 mm / 108.3 in
front track 1689 mm / 66.5 in
rear track 1618 mm / 63.7 in
length 4666 mm / 183.7 in
width 1961 mm / 77.2 in
height 1336 mm / 52.6 in
transmission 6-Speed Manual or F1 Superfast
top speed 329.9 kph / 205 mph
0 - 60 mph 3.6 seconds
Old 26-08-06, 18:09   #5
b_gt
b_gt's Avatar
am pus aici....aston martin..o masina cu pretenti..luxoasa....foarte scumpa...ultimul (liliac) de la lamborghini...un monstru....si o noua masina de la ferrari 599 gtb...ceva nou din partea celor de la maranello....
Old 26-08-06, 19:20   #6
WestCoastCustoms
WestCoastCustoms's Avatar
Lamborghini Murcielago LP640 are viteza maxima de 340 km/h si acceleratia de la 0-100 in 3.4 sec.
WestCoastCustoms is offline   Reply With Quote
Old 26-08-06, 21:31   #7
Alexc2vtr
Alexc2vtr's Avatar
Ferrari 4 ever
Alexc2vtr is offline   Reply With Quote
Old 26-08-06, 23:02   #8
alexSHO
Seat Driver
alexSHO's Avatar
[SEAT]
vanquish... sunt mort dupa miasna asta... oricum la o masina de peste 100k eur cine are bani sa isi ia una si-o ia pt ca ii place nu ca ar avea 0.2 acceleratie mai buna sau 10 km mai mult la viteza maxima or shits like this
alexSHO is offline   Reply With Quote
Old 27-08-06, 23:33   #9
GabiByte
GabiByte's Avatar
Incepem cu inceputu:
ferrari 240.000
lambo 310.000
aston 255.000
Ferrariu iti ofera 611cp
Lambou 640cp
Aston 520cp
La preturile astea si performantele acestea Astonu clar nu isi justifica pretul.
Ca si interior e clar castigator si cred ca suntem cu totii de acord.
Ca si performante, Ferrari e castigator.
Ca si aspect, Lambo bate orice.
In concluzie, nu merita comparate. Orice masina peste 100.000 euro e mai mult decat suficienta pentru a indeplini orice cerinta. Ca sa zica unu "mie imi place Ferrari" si altu "mie imi place Lambo", n-are sens. Eu as merge pentru Ferrari, e cel mai ieftin, e al naibii de rapid, are 4 locuri, iti ofera calitate la fabricatie si materiale si are logoul cel mai puternic pe capota.
<a href="http://copycenter.alfasoft.ro">Copy Center Cluj</a>
GabiByte is offline   Reply With Quote
Old 01-09-06, 20:13   #10
andrE1
VANQUISH rulezz
andrE1 is offline   Reply With Quote
Old 01-09-06, 20:26   #11
Spark
Suzuki Driver
Spark's Avatar
[Suzuki]
aston martin dak vrei ca masina sa fie putzin mai clasica si luxoasa cu tot cu performantze ... (lupu` in piele de oaie)
sau lambo` pe aspect agresiv de masina sportiva si de asemenea cu perormante ridicate (dar si un pret pe masura)
Spark is offline   Reply With Quote
Old 04-09-06, 12:52   #12
BLinKY
Toate is superbe si foarte performante, dar totusi Aston Martinu mi se pare cam scump in raport cu performantele chiar daca arata frumos.
Alegerea mea ar fi
Lambo----1----imi place foarte mult si are nijte performante foarte bune
Ferrari----2----Performante foarte bune ,aspect frumos dar mai putin frumos dekat lambo
Aston Martin----3----Aspect foarte reusit, performante bune, perfotmate/pret nu imi prea place raportul
BLinKY is offline   Reply With Quote
Old 13-09-06, 00:53   #13
05wnd
05wnd's Avatar
Locul I - Ferrari ...............doi si trei oricare
05wnd is offline   Reply With Quote
Old 13-09-06, 15:34   #14
AR33COP
Audi Driver
AR33COP's Avatar
tot lamborghini.are de toate + quattro.
AR33COP is offline   Reply With Quote
Old 13-09-06, 15:52   #15
3SGE
3SGE's Avatar
Cred ca la asa masini performantele zic totul, nu? Deci aleg clar Ferrari!
3SGE is offline   Reply With Quote
