Old 02-07-08, 16:42   #1
boy_wonder
boy_wonder's Avatar
Default Audi A5 3.0 TDI White Speed by Senner Tuning
White Speed se numeste ultima creatie a celor de la Senner Tuning si are la baza modelul Audi A5 3.0 TDI.
Tunerul german a dotat coupe-ul celor de la Audi cu insertii din fibra de carbon si un nou set de jante din aliaj de 21 inci. Partea tehnica a fost si ea modificata, cei de la Senner Tuning urcand puterea motorului 3.0 TDI pana la 300 cai putere (de la 240 CP) si 610 Nm. Multumita acestei cresteri de putere, A5 Coupe atinge acum o viteza maxima de 280 km/h. Alte imbunatatiri includ si o noua suspensie care micsoreaza garda la sol cu 40 milimetri.
ID:	580841   Click image for larger version
ID:	580842   Click image for larger version
ID:	580844   Click image for larger version
ID:	580845   Click image for larger version
ID:	580847   Click image for larger version
ID:	580848   Click image for larger version
ID:	580850   Click image for larger version
ID:	580854   Click image for larger version
ID:	580856   Click image for larger version
ID:	580857   Click image for larger version
ID:	580859   Click image for larger version
ID:	580860   Click image for larger version
Old 02-07-08, 17:18   #2
tEaRsmAd
tEaRsmAd's Avatar
Default Re: Audi A5 3.0 TDI White Speed by Senner Tuning
dAAAmNN !!! a bEassT !!! .. carb0nu` aLa da prEa bNe .. ! :X ..
tEaRsmAd is offline   Reply With Quote
Old 02-07-08, 17:40   #3
adrian46
adrian46's Avatar
ohhh daaaa
adrian46 is offline   Reply With Quote
Old 02-07-08, 17:46   #4
SV25MBN
Chevrolet Driver
SV25MBN's Avatar
[CHEVROLET]
A5`u este una din cele mai frumoase masini de pe piata la ora actuala, alaturi de alte modele din gama Audi, la care toti tunerii se inghesuie sa le modifice si sa isi aduca si ei aportul la designul/performantele masinii. Cu adevarat frumoasa aceasta masina.
SV25MBN is offline   Reply With Quote
Old 02-07-08, 18:53   #5
CT90SNR
CT90SNR's Avatar
Baaaaaaaaaaaaaaaaaaaaaa , Senner , ma cheama pe mine )
CT90SNR is offline   Reply With Quote
Old 02-07-08, 21:01   #6
ct_23_msg_1
ct_23_msg_1's Avatar
frumoasa masina au tunat-o nemtii cu gust .Adevarul e ca ce e al nemtilor e al lor.sa le vedem si la noi cat mai repede
ct_23_msg_1 is offline   Reply With Quote
Old 02-07-08, 21:48   #7
22VIN
Opel Driver
22VIN's Avatar
normal ca trebuia sa fie TDI... un idol pentru sportivitate - diesel
nu zic ca n-ar fi puternic, e chiar foarte puternic, dar aici vorbim de o masina care se vrea sportiva cu tot acel carbon, esapament, jenti etc
Old 02-07-08, 22:07   #8
adrian78bmw
adrian78bmw's Avatar
nu prea cred ca prinde 280 in rest ce sa zic un tuning de bun gust chiar ca a5 e o masina frumoasa si alb ii sta si mai bine dar totusi e cam scumpa..
adrian78bmw is offline   Reply With Quote
Old 02-07-08, 22:50   #9
nu prinde 280 ??? !!!! fac pariu ca prinde......
ON TOPIC : imi place .....mai ales fapru ca e mai lasata cu 4 cm chiar se vede... si imi plac deasemenea jentile
Old 02-07-08, 23:17   #10
steffan
Ford Driver
steffan's Avatar
frumos foc.. totusi pacat k este TDI...
Old 03-07-08, 02:28   #11
SV25MBN
Chevrolet Driver
SV25MBN's Avatar
[CHEVROLET]
Nu crezi ca prinde ? De ce, crezi ca au zis doar o cifra asa sa se laude si apoi sa se faca de ras cand de fapt masina lor nu se conformeaza? Nu cred. Si sunt totusi 300cp.
Old 03-07-08, 08:13   #12
stecherro
stecherro's Avatar
aici nu e vb de cai...ca sunt 300...un a8 vechi simplu de 4,2 are 315 si daca ii scoti limitarea se duce..nu vad asta de ce nu s-ar duce e totusi audi...:-@
.....vectra cu care ti-a zis ma-ta sa NU te pui....
stecherro is offline   Reply With Quote
Old 03-07-08, 12:38   #13
fulgerash
A5 e frumos si stoc
fulgerash is offline   Reply With Quote
Old 03-07-08, 13:42   #14
vizu
vizu's Avatar
ei se tem k nu fuge asa tare k e diesel dar uita k audi castiga la Le-Mans cu motoru v12 TDI ... si plus k are 600nm e ceva ...imi plac mult jantele si per total arata bine
you're life's on the line.....so you better reach the finish...
vizu is offline   Reply With Quote
Old 03-07-08, 14:09   #15
ciprian.20
imi place
ciprian.20 is offline   Reply With Quote
