-   -   Peugeot 306 GTI vs Fiat Bravo HGT vs Golf 4 GTI (https://forum.4tuning.ro/55-versus-auto/25956-peugeot-306-gti-vs-fiat-bravo-hgt-vs-golf-4-gti.html)
BASU 25-10-06 17:36
10 Attachment(s)
Peugout 306 GTI
https://forum.4tuning.ro/imagehosting...f7a682fa0d.jpg
Aerodynamics
Drag coefficient 0.320
Manufacturer Peugeot
Type S-4
DOHC
16 valves total
4 valves per cylinder
Displacement 1998 cc
Compression ratio 10.80:1
Fuel system SFi
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output 167.0 bhp (124.5 kW)@6500 rpm
Max. torque 197.0 Nm (145 lbft)@5500 rpm
Performance
0-100km/h 7.90s
0-Quarter-mile 16.40s
0-Kilometre 29.20s
Top speed 209 km/h (130 mph)
Power-to-weight 137.56 bhp/ton
Weight 1214 kg
Weight distribution (Front) 64.00 %
Fiat Bravo HGT
https://forum.4tuning.ro/imagehosting...f7a6890071.jpg
Manufacturer Fiat
Type S-5
DOHC
20 valves total
Compression ratio 10.70:1
Fuel system SMPFi
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output 152.0 bhp (113.3 kW)@65000 rpm
Max. torque 186.0 Nm (137 lbft)@3750 rpm
performance
0-100km/h 8.00s
0-Quarter-mile
0-Kilometre 29.00s
Top speed 213 km/h (132 mph)
Power-to-weight 127.73 bhp/ton
Volkswage Golf 4 GTI
https://forum.4tuning.ro/imagehosting...f7a68a1a60.jpg
Engine
Engine code AUM
Engine type Otto, Front transversal
Number of cylinders 4, In-line
Engine capacity 1781 cm3
Number of valves 20 DOHC
Fuel Petrol, Injection by cylinder
Supercharging Turbo + Intercooler
Compression ratio 9,3
Max Power 150cp 110 kW@5700 rpm
Max torque 210 Nm@1750 rpm
weight 1279 kg
Performance
Top speed 216 km/h
Acceleration 0-100 km/h 8,5 s
:arrow: Filmul Top Gear Pug 306gti vs fiat HGT vs Golf GTI
nadir 25-10-06 18:13
Re: Peugout 306 GTI vs Fiat Bravo HGT vs Golf 4 GTI
fara sa clipesc am ales golful
lol este vrb de 1,8T the best engine ever ! sa fim seriosi
BASU 25-10-06 18:23
nu stiu daca motorul 1.8T este cel mai bun... dar este cel mai usor tunabil
dar in configuratia de 150cp ramane in ruma pe langa cei 2 rivali aspirati :)
3SGE 25-10-06 18:30
aleg 306 GTI, pt ca are o cunostinta un 306 LE MANS si am vazut cum merge, deci prin urmare cred ca si 306 GTI trage aproape la fel. Cat despre Fiat HGT nu sunt deloc impresionat.
fuzzy 25-10-06 18:58
aleg Fiat, dar nu pentru performante ci pentru look...performantele nu sunt de neglijat dar nu ma uit la o secunda sau doua pana la suta... desi cuplul golfului imi cam face cu ochiul ;)
GTI 25-10-06 20:08
As alege Pug 306 GTI pt ca Peugeot are experienta in sportul cu motor (nu ma refer aici fata de cei doi rivali) si are cateva legende ale raliurilor si rally-raid-urilor.
Golf 4 GTI e slabutz stock insa se poate obtine destul de multa putere ieftin (chip tuning-ul creste puterea la 192CP) si individualizarea atat exterioara cat si interioara e minima.
Fiat Bravo HGT are un design placut si motor cu un sound foarte placut fiind in 5 cilindrii.Are si curba de cuplu buna.
Eugen_TL 25-10-06 20:51
asa cum se punea problema si in filmuletz ...pt ce il vrei ! daca vrei sa te plimbi cu mia multi..sa mergi la piata plm alegi GOLF ( imi da si senzatia ca e mai masina decat celelalte doua...) fiatu doar ca design imi place ...iar peugeotul e super simpatic,ador masinutza asta,iar la liniutza si FUN a castigat :) ... deci daca as vrea o masina sa fie si practica as alege GOLFU daca as vrea o masina doar pt mine mai mica 2 usi PEUGEOTUL.. concluzie: intre astea doua cam grea alegere... totusi ALEG GOLFU
tfsi 26-10-06 00:26
peugeotul e foarte reusit,sportiv,accesibil.golf 4 gti e marea dezamagire...dintre toate gtiurile create de ei...iar fiatul nu s-a prea vandut si nu a prea ieshit in evidenta,a fost si lansat intr-o perioada in care fiatul nu avea o imagine prea buna.castigator e peugeotul
teddy 26-10-06 02:43
aleg 306. singurul ei dezavantaj este ca arata ca o masina de 15 ani vechime.
golful nu il aleg pentru simplu fapt ca a fost una din cele mai mari dezamagiri si rateuri date de Volkswagen.
bogdan_wrc 26-10-06 09:00
golf. 1.8T ..de 180. si cel de 150. nu numai pt motor, dar si pt feeling. vezi ca in poze nu e pusa corecta imaginea. si asta tot GTI e, cel de 25 de ani ;)
pe locul II vine 306. S16, mai exact ;)
alin 26-10-06 12:51
am ales FIAT-ul, pentru design...
baghy83 26-10-06 13:42
306.stock e cel mai puternic.si nu are toata lumea
GTI 26-10-06 13:42
bogdan_wrc,varianta aniversara de 25 de ani GTI e rara,iar varianta de 150CP e slaba.La ce te referi cand spui feeling?
bogdan_wrc 26-10-06 13:49
la condus. la bord. la cum stai in el. adevarta ca cel de 150 de slab. dar GTI inseamna si ala de 180, nu? si nu e chiar rara! vezi pe mobile.de cate sunt ;) cea de 25 de ani e rara, dar cea de 180 nu inseamna doar cea de 25..get my hint ?
bordul de 306 e urat cu spume, iar la fiat (nu stiu cum e exact la HGT) plactisul e cam calitate slaba. parerea mea.
sortex 26-10-06 15:17
peugeot dupa mine cred ca e cel mai usor
