Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Pachete Audio: Statie+Sub, HU+difuzoare, etc
Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc
Old 17-07-14, 23:19   #1
X3M_5P33D3R
X3M_5P33D3R's Avatar
Red face Vand pachet 141+ db
De vanzare:
Amp mic: Hollywood HXA 20
Amplificator 2 canale, clasa A/B
Putere Nominala(RMS):
2 x 100 W - 4 ohmi
2 x 175 W - 2 ohmi
1 x 350 W - 4 ohmi ( in punte )
Raport semnal/zgomot >80dB
Raspuns in frecventa 15Hz~25KHz
Distorsiuni THD <0,05% ( la puterea maxima )
Filtru Subsonic 15-50Hz
Filtru High pass 20Hz~250Hz
Filtru Low pass 20Hz~250Hz
Sensibilitate intrare:200mV-5V
Impedanta de intrare 22Kohm
Pornire Soft-Start
Sigurante 1 x 40A
Protectie la supra-voltaj, scurt-circuit, inversarea polaritatii si supra-incalzire
Dimensiuni:200 x 140 x 54 mm
Amp mare: Monacor CarPower D-Rex 3000
Max. power 3,000WMAX
RMS power 2O 1 x 2,500WRMS
RMS power 4O 1 x 1,500WRMS
Frequency range 20-150Hz
Load impedance (min.) 2O
Input sensitivity (line) 0.3-8V
S/N ratio > 85dB
THD < 0.5%
Low-pass 40-150Hz, 24dB/oct.
Subsonic 15-50Hz, 18dB/oct.
Bass boost 30-60Hz, 0dB - (+6dB)
Operating voltage 11-16V DC current /200A
Connections screw terminals
Line 1 x RCA L/R
Speakers screw terminals
Line 1 x RCA L/R
Remote control RJ45
Admiss. ambient temp. 0-45 °C
Dimensions 300x60x565mm
Weight 8.9kg
Sub: RE AUDIO SE 15"
Dual 2 ohm Voice Coils
1200 watts peak output
15" competition grade subwoofer
600 watts pure RMS
Qes: .55
Qms: 4.3
Qts: .49
Free Air Resonance -Fs: 22 Hz
Vas: 209 liters
Overall Diameter - 15.65"
Bolt Hole Circle - 14.85"
Weight - 24 lbs.
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency - 87.1 dB SPL @ 1w/m
DC Resistance -Re: 2.8 ohm
Mounting Depth - 7.75"
Dual Composite 2-piece Cone
Rubatek Foam Surround
Cast Aluminum Basket
Tork-Tite Terminal
3" 4-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Triple Stack Maganets
Progressive Spiders
Wrap around Rubber Gasket
Cutie: @46 hz
MDF
Volum si dimensiuni le pun maine.
Cabluri: Hollywood HE-3024
5+1m 4GA PC
5m 12GA SC
2CH RCA Twisted
5m 18GA Remote
80A AGU Holder
Terminal soldered
Detalii minore:
amp mic + sub & cutie scor 138+ (baterie varta silver 75amp, alternator stock)
amp mare + sub & cutie scor 141+ (baterie varta silver 75amp, alternator stock)
Se poate vedea/incerca in Arad
Contact: telefon 0733 411 115 preferabil L-V dupa ora 16
mail x3m_5p33d3r@yahoo.com
skype x3m_3p33d3r
Pret: 2700 lei
ID:	3008991   Click image for larger version
ID:	3008992   Click image for larger version
ID:	3008994   Click image for larger version
ID:	3008995   Click image for larger version
ID:	3008997   Click image for larger version
X3M_5P33D3R is offline   Reply With Quote
Old 24-07-14, 23:16   #2
X3M_5P33D3R
Default Re: Vand pachet 141+ db
2 Video cu ele in functiune
https://www.youtube.com/watch?v=bVTnxBtWEGo
https://www.youtube.com/watch?v=r2HBonW0mKQ
Old 26-07-14, 07:33   #3
X3M_5P33D3R
Dimensiunile cutiei:
Lungime 950 mm
Inaltime 405 mm
Adancime 440 mm
Old 28-08-14, 19:45   #4
X3M_5P33D3R
Pret nou: 2400 tot
Old 16-09-14, 11:43   #5
X3M_5P33D3R
Pretul revine la 2700 lei
Old 20-09-14, 16:02   #6
X3M_5P33D3R
Pret nou: 2300 Lei
Old 03-10-14, 17:53   #7
X3M_5P33D3R
2100 Lei
Old 15-11-14, 20:49   #8
X3M_5P33D3R
1800 LEi
