Vand Aparat taiere cu plasma HYPERTHERM Powermax350 Hand Held Plasma Cutting 220v
Aparatul este achizitionat de nou , folosit foarte putin timp pentru modificarea esapamentelor din inox.
La cerere pot oferii si factura fiscala.
Detalii tehnice:
Ambient temperature and duty cycle
Apparent input power
Input voltage/Input current 2.25 kW output
Gas type
Supplied air pressure and flowrate
Power supply pressure regulator setting
PAC110 Torch:
Recommended cutting capacity
Maximum cutting capacity
Severance cutting capacity
Gas flow 255 VDC
17-27 Amps
27 Amps - 91 VDC - 104°F
35% (I=27A, U=91V)
60% (I=21A, U=88V)
100% (I=17A, U=87V)
Power supplies will operate
between 14° and 104°F.
Power supplies in ambient
temp above 86°F may show
some decrease in duty cycle
3.8 kVA
115/230V/33.3/17.8A 1-Ph, 60Hz
Air - clean, dry, oil free
70-120 psi (4.8-8.3 bar)
270 scfh/4.5 scfm
(127 l/min) supplied to power
60 psi (4.1 bar) flowing
1/4" - 25A (35% duty cycle)
3/8" - 25A (35% duty cycle)
1/2" - 25A (35% duty cycle)
270 scfh/4.5 scfm - 60 psi
(127 l/min - 4.1 bar)
Equipped With
PAC110 Torch
Pret 1000 Eur negociabil
Tel : 0734262330
