Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 17-12-11, 20:29   #1
ct77pia
ct77pia's Avatar
[Anonymous Motorsport ]
Default cumpar turbina
ma intereseaza urmatoarele turbine
ihi vf34 sau 35
td 06
td04
gt28
astept oferte
ct77pia is offline   Reply With Quote
Old 30-12-11, 17:21   #2
gogu
Default Re: cumpar turbina
Cat dai pe una de suby?
gogu is offline   Reply With Quote
Old 02-01-12, 21:44   #3
ct77pia
ct77pia's Avatar
lasa ca imi iau din alta parte
Old 03-01-12, 14:56   #4
Nba1
GT2860 turbo turbocharger
TD04HL T25 Flange / 6cm
Product Info
Item Name
Kinugawa MHI TD04HL / 6cm Turbine Housing with T25 Flange
Item No.
0700-812-040
Application
- Mitsubishi/Greddy TD04HL Turbo (45.6/52mm)
- It does NOT fit TD04H turbo. (44.2 / 52mm Turbine wheel.)
A/R
- 6cm
Quantity
- 1 x Turbine Housing ported to fit TD04HL wheel
Manufacture
-Kinugawa Turbo
daca mai vrei si pt celelalte iti mai arat cateva .
Name:	gt 28 turbine.jpg
Nba1 is offline   Reply With Quote
Old 11-01-12, 11:24   #5
Balaurr
Balaurr's Avatar
si un pret ai?
Balaurr is offline   Reply With Quote
Old 11-01-12, 12:02   #6
Nba1
Ai PM .
Old 14-01-12, 11:52   #7
Nba1
ihi vf34 daca te mai intereseaza :
Part No: VA660060
Item Name: IHI VF34 TURBO CHARGER
Application: BOLT-ON FOR SUBARU IMPREZA WRX EJ20/EJ25
Spec: COMES WITH WATER FITTINGS, OIL DRAIN FITTING, ACTUATOR
CAN BE TUNE TO 350HP +
