buna ziua am si eu o nelămurire sunt compatibile cele două, am boxele hertz
diametru midbass - 170 mm
crossovere pasive tip "pe fir"
magnet din ferita
con din hartie presata
putere nominala - 80W RMS
putere maxima - 160W RMS
raspuns in frecventa - 50-23kHz
sensibilitate - 93dB
impedanta - 4ohmi
si as dori sa le un la Blaupunkt GTA 480, cu următoarele specificații, Max. power 4 x 160 / 2 x 425W into 4 ohms
Max. power 4 x 210 W into 2 ohms
RMS power 4 x 75 / 2 x 210W into 4 ohms
RMS power 4 x 105W into 2 ohms
Direct aux-input feature (front / rear stereo channels with 3.5mm stereo jack plug connectors) allows MP3 Walkman or navigation system to be plugged directly into to amplifier and mixed with other signal sources. Volume levels of each source can be independently set
Frequency response 10 Hz - 35 kHz
Signal to noise ratio > 95dB/A
THD at rated power < 0.03%
Input impedance > 10 kOhms
2 ohm stability (4 ohm bridged)
Input signal 0.3 - 8.0V
Front and rear channel low pass filter: 50 - 250Hz variable
Front and rear channel high pass filter: 50 - 250Hz variable
Front and rear channel bass boost 0 - 12dB at 45Hz
Front and rear channel crossover selector
Problema mea e ca la specificatii amplificatorul e stabil in 2 ohmi si doar in punte 4 ohmi, sunt compatibile? mu.ltumesc anticipat
