Salut!!
Va rog sa imi spuneti ce proiect de incinta sa fac pentru un difuzor Dls W610:
Dimensions:
Diameter 262 mm
Mounting depth 109 mm
Mounting hole diameter 232 mm
Nominal power handling 180 W
Maximum power 360 W
Nominal impedance, Z 4 ohms
Sensitivity, 1 W / 1 m 90 dB
Frequency response 20-1000 Hz
Fs, resonant frequency 32,9 Hz
Voice coil diameter 50 mm, 2”
Voice coil height 22 mm
Voice coil wire Copper
Number of layers 4
DC resistance 3,6 ohm
Voice coil inductance, 1 kHz 1,58 mH
Magnet system Ferrite
Magnet weight 40 oz
Magnet diameter 145 mm
BL product 15,98
Max. linear excursion, X max +- 9 mm
Suspension compliance, CMS 290
Mechanical Q factor, QMS 3,63
Electrical Q factor, QES 0,23
Total Q factor, QTS 0,22
Moving mass, MMS 80,72 gr
Equivalent Cas Air load, VAS 40,3 liters
Cone / Dome material PPC
SD - Effective piston area 314,6 cm2
Net weight 3,72 kg
Mentionez ca momentan este intr-o cutie sealed de ~20L in portbagajul unui logan si nu sunt multumit deloc de rezultat.
Ca statie de amplificare am un Dls ca31.
Mersi!
