Tind sa cred ca tipu din video vb despre cele 2 produse.
https://www.youtube.com/watch?v=aehY72CmxyU
Am gasit ceva date despre ele pe un forum din america.
Damplifier Pro is the WRONG product to compare to Dynamat Extreme.
Instead, you should be comparing our regular Damplifier to Dynamat Extreme.
Here is how it works:
Dynamat Extreme
Butyl adhesive
4 mil foil
.45 lbs per sq ft.
Damplifier
Butyl adhesive
4 mil foil
.45 lbs per sq ft.
Damplifier Pro
Butyl adhesive
6 mil foil
.65 lbs per sq ft.
You can see that Damplifier and Dynamat Extreme are equal in terms of specs, where as Damplifier Pro offers 50% more foil and 30% more adhesive by weight.
Hope that helps!
