Zona tehnica Opel Zona tehnica, secrete, tips&tricks Opel |
24-01-07, 14:01
Opel Astra G 1.4 16v - Turbo
Am un opel astra 1.4 16v twinport (90 cp) si ma gandeam daca as putea sa pun o turbina pe el
Daca se poate:
cam cat m-ar costa ?
cat ar influenta puterea/cuplul motorului ?
si unde se poate face asa ceva ?
19-05-07, 17:26
Re: Opel Astra G 1.4 16v - Turbo
Costa ~4000 eur si ajungi la 180cp.
06-06-07, 23:05
la banii astia iti iei alta masina...eu zic ca nu se merita
07-06-07, 14:34
Member of: [Moderators] [No Limits racing team]
Uite..am eu ceva care cred ca te-ar interesa.
Hello,
thanks a lot for your interest in our products.
For the Opel Astra H 1,4l 16V Twinport with 66kW (engine code: Z14XEP) we could offer as following:
Performance kits for OPEL Z14XEP Engines
Astra H and Corsa C 1,4 16V Twinport
Step I : Upgrade to 85kW / 115HP
includes:
Flowtec-inlet manifold with a complete 1186,--
software update of the engine control
Fitting of the Flowtec-inlet manifold 196,--
at dbilas dynamic
Completeprice including fitting at dbilas dynamic 1340,--
You save 42,--
Step II : Upgrade to 91kW / 124HP
includes:
A set of sport camshafts 472,--
Fitting of the sport camshafts 196,--
at dbilas dynamic
Completeprice including fitting at dbilas dynamic 1960,--
You save 89,--
Step III : Upgrade to 102kW / 139HP
includes:
Cylinderhead and valve modification 815,--
Fitting of the cylinderhead 717,--
and of the sport camshafts
at dbilas dynamic
Completeprice including fitting at dbilas dynamic 3270,--
You save 115,--
All prices are in EURO and include 16 % VAT.
The flowtec - inlet manifold is very easy to fit.
The flowtec - inlet manifold is pre-mounted and ready to be installed. The kit contains fitting instructions, the manifold, hoses and all necessary small parts.
There is also included a software update of the ECU. Therefore you have to send us the ECU of the car. If we have reiceive it we will make the update and send it back on the same day.
Furthermore we have a sport filter "FlowMaster" in our program.
The kit contains the FlowMaster air filter box with filter cartridge, hoses and necessary holders.
The price for the sport filter is 199,-- incl. 19 % VAT.
Additional we could offer an air inlet dukt "FlowPipe" for 110,20 incl. 19 % VAT.
The air inlet dukt fit with the original air filter box or with the FlowMaster.
Advantages of the both parts:
more fresh air = - less consumption
- better torque
- super sound
Attention! If you order FlowMaster-System and FlowPipe you save 10 %.
For the Opel Astra H with the Z14XEP engine we could also offer a turbo - system:
Turbosystem Opel Astra H, Corsa C, Meriva A, Tigra TwinTop Z14XEP 4.982,20
Leistungssteigerung auf 180PS (Performance increase up to 180HP)
Wenn das Flowtec-Saugrohr schon vorhanden ist. 4.170,20
If the Flowtec manifold is existing.
Einbau des Turboladersystems (Fitting) 640,00
All stated prices includes 19 % VAT.
The dbilas dynamic Turbocharger systems contain: Flowtec manifold, Turbocharger, dbilas dyanmic exhaust manifold, intercooler, FlowMaster air filter system with FlowPipe, a complete inox exhaust with sport catalytic converter, intercooler pipes with hoses, oil- and coolantlines.
The Kit also includes the software update of the ECU.
For further questions do not hesitate to contact us.
Best regards,
dbilas dynamic
Maybachstr. 3
63322 Rφdermark
Tel:+49(0)6074-93328
Fax:+49(0)6074-93316
25-07-07, 14:37
Mai bine ii pui un chip tuning care creste cu 20-40 de cai puterea un filtru sport si o evacoare completa si ajungi de la 90 la 150 lejer si nu te costa atat eu am corsa si iam pus filtru si chip dsi de la 1.2 80 de cai acum am 1.2 100 de cai si rupe cu 190km/h
26-07-07, 09:36
Extreme Racing Member
Member of: [Extreme Racing] [PARTICIPANT CURSE] [Opel]
bah voi cititi ce scrieti?
cum sa pui chip la 1.4 benzinar shi sa castigi mai mult de 5 cp? iar filtru shi evacuarea inca 5 ...
ce oameni
26-07-07, 12:52
Frate pe testar imi arata 100 de cai acum nu stiu cum au reusit aia
26-07-07, 13:00
Audi Driver
Member of: [AUDI]
doar 100? da drumul la intreaga hergelie de 265 de cai..... cum doar 100? cipul e din ala magnetic si se prinde in piept? nu fii timid..spune sincer cat ai...
deci motorul are stock 70-80 de cai asiprat, dar cipul, ii da 40? eu zic sa faci varianta race..ca sigur iti da 100 de cai in plus.
ce oameni...
Objects in the mirror tend to disappear
It will never have enough power until I can spin the wheels at the end of the straightaway in high gear
13-11-07, 04:09
fratilor,lamuriti-ma si pe mine pana la urma,ca si eu am tot 14 16v de 90cp,cu cip te ajuta la ceva?ca eu ma indoiesc in legatura cu filtru inafara de un sunet mai placut mai nimic,vreau sa imi spuneti si mie daca va ajuta,adica daca are cineva,unde si-a pus si cat l-a costat??ms mult de tot
16-11-07, 17:18
Member of: [BMW]
mama foss esti cel mai tare forumist ever sa mor eu daca nu esti tare de tot in mecanica ?? bai taceti ma daca nu stiti ca va faceti de *** rau de tot va citeste o tara inteaga esti nebun?/ nebunule
1.4 ...............
16-11-07, 17:20
Member of: [BMW]
si zimi si mie ce tester iti arata tie cai in afara de dyno ca sincer poate sunt mai prost si neandertal si nu stiu???
17-11-07, 00:54
Member of: [Opel]
CIPu' da bn decat la turbo...nu mai intru in detalii
17-11-07, 02:42
ai turbina la 14 16v?adik la motoru de 90cp i-ai pus turbo?cat te-a dus?ms mult
17-11-07, 10:19
Member of: [Opel]
nu frate nu are turbo motoru de 1.4 16V.Nici nu i-am poos,nici makr nu am asa ceva,eu sunt pe 1.7DTI.Are un tov de al meu(partea a doua).Nu se merita sa ii pooi turbo la asta micu de 1.4 16V.Vinzi masina si mai pui banii de trubo si iti iei un Bertone Z20LET de 2005 si mai raman si bani.Asa k nu ai nici-o afacere doar daca esti maniac dupa 1.4 16V sau ceva de genu
17-11-07, 18:16
Member of: [PARTICIPANT CURSE] [Opel]
Total de acord cu cele precizate mai sus. Pentru acest motor nu merita munca vs. ceea ce o sa realizezi.
Bafta
