Inchide Acest site foloseste cookies. Prin navigarea pe acest site, va exprimati acordul asupra folosirii cookie-urilor. Citeste mai mult...
Q&A
Old 25-01-10, 17:03   #1426
Daniel_Toa
Daniel_Toa's Avatar
Oras: Turnu Magurele
Originally Posted by passatb4 View Post
=)) ft tare asta))
poi uitate si u si bagai daca nu are da nu cred ca nu ia bagat
Si unde sa ma uit daca mai are ?
Daniel_Toa is offline   Reply With Quote
Old 25-01-10, 17:04   #1427
trafy-vr6
trafy-vr6's Avatar
Oras: Rm.Valcea
[Shadows Racing Team]
[ALFA ROMEO]
in cutie))))))))))))) glumeam...
trafy-vr6 is offline   Reply With Quote
Old 25-01-10, 17:08   #1428
rdy4ever
rdy4ever's Avatar
Oras: Bucuresti
Originally Posted by Daniel_Toa View Post
Trafy ma referam daca ai bagat ulei in cutia mea cand masina era la tine
rdy4ever - n am auzit pana acum de winter pack
BMW E36 Features You Don’t Know About
1. Speed Sensitive Volume (Harmon Kardon Audio System).
2. Speed Sensitive Wipers:- In the rain, the wipers will change their speed according to the car speed. The 3 settings for the wipers speed are:-
a. Intermittent:- Wipers go intermittently at speeds above 3 mph (about) and do not work at all when stopped.
b. Speed one:- Wipers go slowly at speeds above 3 mph (about) and go intermittently when stopped.
c. Speed two:- Wipers go fast at speeds above 3 mph (about) and slowly when stopped.
3. Closing All Windows and Sunroof By Holding Key in the Lock Position. (Didn’t work on my BMW E36 1993 318is though. I think it’s a 94+ feature). Take a look at this BMW E36 M3 Review and Info.
4. Gas Door Closes with Central Lock.
5. Heated Windshield Nozzles (Winter Package).6. Heated Door Locks (Winter Package).
7. Tilt Steering Wheel. Anyone got this?
8. Cupholder/Central Console is pre-wired for the ashtray light.
9. Secret OBC Functions.
10. Heated Mirrors.
11. The BC Button On The Signal Selector. Just click your signal stick towards the steering wheel column. You can switch the OBC functions this way.
12. After you park the car you can switch on the parking lights on one side of the car only. To do this, just switch the car off and push the indicator stalk all the way up or down (it’s quite stiff). The right or the left parking light will turn on.
mai vezi aici.
Old 25-01-10, 17:10   #1429
Daniel_Toa
Daniel_Toa's Avatar
Da vad , ca exista si versiunea cu winter pack , totusi unde ma uit sa vad daca mai are nevoie cutia de ulei ?
Old 25-01-10, 17:19   #1430
rdy4ever
rdy4ever's Avatar
Oras: Bucuresti
mai grav cu temperaturile astea extreme e ca m-am uitat ieri la "conductele" de la directie (acele furtunase cauciucate la exterior care vin pana la roata, nu stiu exact cum se numesc), si au inghetat bocna. Sper sa nu devina casante de la gerul asa si sa pocneasca vreuna la un moment dat. Plus ca s-a depus un strat de gheata pe ele destul de gros si mi-e si frica sa incerc sa-l desprind, sa nu cumba sa fortez ceva.:-s
Old 25-01-10, 17:22   #1431
passatb4
passatb4's Avatar
Oras: BUCURESTI
eu unu nu am avut de aface cu astea da cred ca la carcasa ambreiajului pe partea dreapta a masinii, acolo unde se face si umplerea/golirea poti verifica
eu am un fix schimb tot ce apartine de ulei si lichid frana sau directie si nu-l schimb eu ci mecanicu de aia si ma injura ca nu stau pe langa el
passatb4 is offline   Reply With Quote
Old 25-01-10, 17:41   #1432
hanibaL995
Oras: Bucuresti
am mai umblat prin alea tot nu se misca acul de kilometraj si benzina ,alte sugestii????
hanibaL995 is offline   Reply With Quote
Old 25-01-10, 17:45   #1433
hanibaL995
Oras: Bucuresti
si am facut testul pentru bord si acurile s-au dus pana in capat ,adica merg
Old 25-01-10, 17:50   #1434
adriano9
adriano9's Avatar
Oras: Baia Mare
de cand cu frigurile astea parca merge mai greu volanul,directia...
adriano9 is offline   Reply With Quote
Old 25-01-10, 17:53   #1435
rdy4ever
rdy4ever's Avatar
Oras: Bucuresti
1.scoate din nou bordul (cu contactul luat), remonteaza toate mufele - vezi sa fie bine infipte (au o siguranta pe ele pe care o ridici cand le scoti si o tragi in jos cand le pui la loc), montezi bordul.
2. Pui contactul in prima pozitie, apesi butonul de resetat kilometrii, cu butonul apasat, treci contactul in pozitia 2. Ar trebui in momentul asta sa inceapa testatrea instrumentelor de bord, o sa iti sapara pe display niste numele 1,2,3,... parca merge pana pe la 6-7, apoi o sa se dea toateacele pste cap (o cursa completa). Pornesti motorul si ar trebui sa mearga bordul normal. daca tot nu functioneaza e posibil sa fi intrerupt vreun fir prin spatele bordului, sa fi facut vreun scurt ceva, verifica si sigurantele sa nu fi ars vreuna.
Bafta!
Old 25-01-10, 17:56   #1436
rdy4ever
rdy4ever's Avatar
Oras: Bucuresti
vad ca ai facut deja testul de bord, verifica sigurantele, sa nu se fi ars vreuna (poate te mira dar bordul nu are o singura siguranta). ia o lanterna si uita-te cu atentie la ele (daca sunt de tip vechi vezi cu ochiul care e arsa, fara sa le scoti, daca sunt noi tre sa le scoti pe cele de la bord, nu stiu exact care sunt.
Old 25-01-10, 17:57   #1437
nirolfHD
nirolfHD's Avatar
Oras: Cluj
ms rdy4ever pt faze alea..mi-ai lamurit niste chestii cu stergatoarele alea) m-au pus pe ganduri de cateva ori)) si a mea e din 93 si merge faza cu "Closing All Windows and Sunroof By Holding Key in the Lock Position" nush dc zice ala ca nu ii merge pe masina din 93
nirolfHD is offline   Reply With Quote
Old 25-01-10, 17:59   #1438
passatb4
passatb4's Avatar
Oras: BUCURESTI
da tu ai verificat uleiul la directie
Old 25-01-10, 18:12   #1439
adriano9
adriano9's Avatar
Oras: Baia Mare
maine dimineata o sa ma uit,pana acuma 2-3 zile mergea bine,ma gandeam ca poate ii de la frig
Old 25-01-10, 18:13   #1440
rdy4ever
rdy4ever's Avatar
Oras: Bucuresti
sincer nici mie nu-mi merge faza aia cu inchiderea, dar cred ca am un fir sau mai multe rupte pe la balamaua usii, sau modulul confort defect... era o functie buna pe timp de vara
Old 2010
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
Copyright 2012 4Tuning
