si gata... secretul a luat sfarsit.
Today, I have discovered that there are 2 light sensors in the BMW E36 which are supposed to auto-dim your car’s interior according to the light intesity. I’m not sure if it’s going to work in my car or not. I will have to check it today, but I thought I would post it here first in order to give you something to keep you busy
Anyway, that’s enough … let’s give details:
The BMW E36 has 2 interior light sensors. One in the gauge cluster at the end of the speedometer. I’m sure many has wondered what is that thing looking like a lense there. It’s the auto-dim gauge cluster sensor. Take a look:
It’s supposed to make the gauge cluster light become more intense as it becomes darker outside.
Now for the other sensor, it’s located in the Digital climate control unit and it controls the light intensity of the climate control unit and the OBC (On Board Computer). So, if you don’t have the digital climate control (like me)… now it’s a good time to start crying . Take a look:
For me, as I said before, I didn’t try any of this yet, but I will check it today and make sure it’s working in my car. Please try it in your cars and lets see if it works.
Articolul este preluat de pe bmwe36blog.com si se gaseste aici.
ba s-ar putea sa mearga. pt ca logic ar fi ca acest senzor sa lucreze fix invers (la concluzia asta am ajuns dupa putina gandire). Adica el face bordul mai intens in timpul zilei (pt a fi vizibil in semi-lumina - de ex orele 5-6 PM) si mai reduce din intensitate noaptea (pt a nu deranja la ochi). De aceea ii spune auto-dim.
si eu care credeam ca ledu ala te avertizeaza ca incepe serioasa uzura a motorului cand ii dai viteza maxima.....o sa verific si eu daca e senzor pt intensitate lumini....
mda.dar ca s nu te deranjeze noaptea intensitatea luminii bordului,eu unul am un sistem de reglaj.deci imi pot regla intensitatea iluminarii bordului dupa preferinta.butonul sau rotita se afla in stanga volanului spre partea inferioara a bordului.acolo unde ar trebui sa se afle si reglajul farurilor(eu nu am reglaj la faruri).
Da, asa este. Acea lentila mica este un senzor de lumina. Incercati noaptea sa luminati cu o lanterna de aia mica de la bricheta exact acel punct. Veti observa o intensificare a luminii in ceasurile de la bord, display-ul de la obc si cel de la clima.
pai toate au rotita de reglaj a intensitatii bordului, dar reglajul pe senzor mi se pare ca da +/- 25% pe langa ceea ce ai reglat tu.
Am si eu o nedumerire , cand am schimbat uleiul am bagat 4 litri , iar acum aud pe ici pe colo ca trebuia sa bag 5 litri , altul ca 6 . Este un bmw e36 , 318i din 94 in 4 usi .
Roaga pe cineva care are programul Autodata sa-ti zica.
