Old 07-02-15, 10:24   #1
igor2009
Default Fault Codes OBD,DTC
su varie automobili
VAG COM
16394 P0010 Series 1: failure of the regulator valve timing
16395 P0011 Series 1: shift timing in late parties do not reach the rated value
16396 P0012 Series 1: shift timing in early parties do not reach the rated value
16397 P0013 Series 1 exhaust camshaft: the failure of the regulator valve timing
16398 P0014 Series 1, exhaust camshaft, timing shift in late parties fail to reach a nominal value
16399 P0015 Series 1, exhaust camshaft, timing shift in the early parties do not reach the rated value
16400 P0016 Series 1, position sensor raspredvala.-G40 / crankshaft position sensor-G28: mismatch signals
16401 P0017 Series 1, position sensor raspredvala.-G300 / crankshaft position sensor-G28: mismatch signals
16402 P0018 Series 2 encoder raspredvala.-G163 / crankshaft position sensor-G28: mismatch signals
16403 P0019 Series 2 encoder raspredvala.-G301 / crankshaft position sensor-G28: mismatch signals
16404 P0020 Series 2: The failure of the regulator valve timing
16405 P0021 Series 2: shift timing in late parties do not reach the rated value
16406 P0022 Series 2: shift timing in early parties do not reach the rated value
16407 P0023 Series 2, exhaust camshaft: the failure of the regulator valve timing
16408 P0024 Series 2, exhaust camshaft, timing shift in late parties fail to reach a nominal value
16409 P0025 Series 2, exhaust camshaft, timing shift in the early parties do not reach the rated value
P0030 16414 Bank 1 Sensor 1: break the electrical circuit heating
P0031 16415 Bank 1 Sensor 1: short to ground electrical circuit heating
P0032 16416 Bank 1 Sensor 1: short to positive electrical circuit heating
16417 P0033 Turbocharger bypass valve failure in the electric circuit
16418 P0034 Turbocharger bypass valve short circuit to ground
16419 P0035 Turbocharger bypass valve
P0036 16420 Bank 1 Sensor 2: break the electrical circuit heating
P0037 16421 Bank 1 Sensor 2, electric heating circuit: short circuit to ground
P0038 16422 Bank 1 Sensor 2, short to positive electrical circuit heating
16423 P0039 Turbocharger bypass valve-N249: invalid signal
16424 P0040 messed number 1 Sensor 1 and Bank 2 Sensor 1
16425 P0041 messed number 1 and number 2 probe 2 probe 2
P0042 16426 Bank 1 Sensor 3: Open the circuit heating
P0043 16427 Bank 1 Sensor 3: short to ground electrical circuit heating
P0044 16428 Bank 1 Sensor 3: short to positive electrical circuit heating
16434 P0050 Series 2 Sensor 1: failure in the electric circuit of heating
16435 P0051 Series 2 Sensor 1: short to ground electrical circuit heating
16436 P0052 Series 2 Sensor 1: short to positive electrical circuit heating
16440 P0056 Series 2 Sensor 2: failure in the electric circuit of heating
16441 P0057 Series 2 Sensor 2: short to ground electrical circuit heating
16442 P0058 Series 2 Sensor 2: short to positive electrical circuit heating
16448 P0064 Series 2 Sensor 3: short to positive electrical circuit heating
16449 P0065 pneumatic control valve injectors-N212: invalid signal
16450 P0066 pneumatic control valve injectors-N212: short to ground
16451 P0067 pneumatic control valve injectors-N212: short to positive
16452 P0068 Pressure inlet / air mass <-> deviation angle of the throttle position
16453 P0069 Intake Air Pressure <-> air pressure: improper relationship
16455 P0071 Ambient temperature sensor-G17
16456 P0072 Ambient temperature sensor-G17: too low signal
16457 P0073 Ambient temperature sensor-G17: too high signal
16458 P0074 Ambient temperature sensor-G17: open circuit
16473 P0089 fuel metering valve: implausible signal
16474 P0090 fuel metering valve, a failure in the electrical circuit
16475 P0091 fuel metering valve, a short to ground
16476 P0092 fuel metering valve: short to positive
16481 P0097 Sensor -2- IAT G299: too low signal
16482 P0098 Sensor -2- IAT-G299: too high signal
16483 P0099 Sensor -2- IAT-G299: no signal
16485 P0101 Air flow meter-G70: implausible signal
16486 P0102 Air flow meter-G70: too low signal
16487 P0103 Air flow meter-G70: too high signal
16488 P0104 Air flow meter-G70: no signal
16489 P0105 Pressure Sensor Manifold-G71: Supply Voltage
16490 P0106 ​​Inlet pressure / air pressure => - G71 / -F96: implausible signal
16491 P0107 Inlet pressure / air pressure => - G71 / -F96: too low signal
16492 P0108 Inlet pressure / air pressure => - G71 / -F96: too high signal
16495 P0111 Sensor IAT-G42: implausible signal
16496 P0112 Sensor IAT-G42: too low signal
16497 P0113 Sensor IAT-G42: too high signal
16498 P0114 Sensor IAT-G42: no signal
16500 P0116 Engine Coolant Temperature Sensor-G62: implausible signal
16501 P0117 Engine Coolant Temperature Sensor-G62: too low signal
16502 P0118 Engine Coolant Temperature Sensor-G62, the signal level is too high
16504 P0120 Throttle potentiometer-G69, a fault in the electrical circuit
16505 P0121 Throttle potentiometer-G69, unreliable signal
16506 P0122 Throttle potentiometer-G69: too low signal
16507 P0123 Throttle potentiometer-G69: too high signal
16509 P0125 temperature not reached coolant for lambda control
16512 P0128 valve in the coolant circuit-N214: the temperature is below the control range
P0130 16514 Bank 1 Sensor 1: failure in the electric circuit
P0131 16515 Bank 1 Sensor 1: low voltage
P0132 16516 Bank 1 Sensor 1 voltage too high
P0133 16517 Bank 1 Sensor 1: reaction time is too long
P0134 16518 Bank 1 Sensor 1: No Activity
P0135 16519 Bank 1 Sensor 1: failure in the electric circuit of heating
P0136 16520 Bank 1 Sensor 2: failure in the electric circuit
P0137 16521 Bank 1 Sensor 2: low voltage
P0138 16522 Bank 1 Sensor 2 voltage too high
P0139 16523 Bank 1 Sensor 2: Too low speed signal
P0140 16524 Bank 1 Sensor 2: No Activity
P0141 16525 Bank 1 Sensor 2: failure in the electric circuit of heating
P0142 16526 Bank 1 Sensor 3: failure in the electric circuit
P0143 16527 Bank 1 Sensor 3: voltage too low
P0144 16528 Bank 1 Sensor 3: too high voltage
P0145 16529 Bank 1 Sensor 3: reaction time is too long
P0146 16530 Bank 1 Sensor 3: No Activity
P0147 16531 Bank 1 Sensor 3: failure in the electric circuit of heating
16533 P0149 system to determine the fuel-vozd.smesi (number 1): deviation of the injection time
16534 P0150 Series 2 Sensor 1: failure in the electric circuit
16535 P0151 Series 2 Sensor 1: low voltage
16536 P0152 Series 2 Sensor 1 voltage too high
16537 P0153 Series 2 Sensor 1: reaction time is too long
16538 P0154 Series 2 Sensor 1: No Activity
16539 P0155 Series 2 Sensor 1: failure in the electric circuit of heating
16540 P0156 Series 2 Sensor 2: failure in the electric circuit
16541 P0157 Series 2 Sensor 2: low voltage
16542 P0158 Series 2 Sensor 2 voltage too high
16543 P0159 Series 2 probe 2, the reaction time is too long
16544 P0160 Series 2 Sensor 2: No Activity
16545 P0161 Series 2 Sensor 2: failure in the electric circuit of heating
16546 P0162 Series 2 Sensor 3: failure in the electric circuit
16547 P0163 Series 2 Sensor 3: voltage too low
16548 P0164 Series 2 Sensor 3: too high voltage
16549 P0165 Series 2 Sensor 3: reaction time is too long
16550 P0166 Series 2 Sensor 3: No Activity
16551 P0167 Series 2 Sensor 3: failure in the electric circuit of heating
16554 P0170 Series 1: failure of the system to determine the fuel-vozd.smesi
16555 P0171 Series 1, the system of determining the parameters of fuel-vozd.smesi: too lean
16556 P0172 Series 1, the system of determining the parameters of fuel-vozd.smesi: the mixture is too rich
16557 P0173 Series 2: The failure of the system to determine the fuel-vozd.smesi
16558 P0174 Series 2, the system of determining the parameters of fuel-vozd.smesi: too lean
16559 P0175 Series 2, the system of determining the parameters of fuel-vozd.smesi: the mixture is too rich
16561 P0177 Fuel Quality Sensor G446: implausible signal
16562 P0178 Fuel Quality Sensor G446: Travel lower limit value
16563 P0179 Fuel Quality Sensor G446: the upper limit value is exceeded
16565 P0181 Fuel temperature sensor-G81: implausible signal
16566 P0182 Fuel temperature sensor-G81: short to ground
16567 P0183 Fuel temperature sensor-G81: open circuit / short to positive
16570 P0186 Fuel Temperature Sensor 2-G248: implausible signal
16571 P0187 Fuel Temperature Sensor 2-G248: Short to Ground
16572 P0188 Fuel Temperature Sensor 2-G248: short to positive
16574 P0190 Fuel pressure-G247: a failure in the electrical circuit
16575 P0191 Fuel pressure-G247: implausible signal
16576 P0192 Fuel pressure-G247: Short to Ground
16577 P0193 Fuel pressure-G247: short to positive
16578 P0194 Fuel pressure-G247: open circuit
16580 P0196 Oil temperature sensor-G8: invalid signal
16581 P0197 Oil temperature sensor-G8: the signal level is too low
16582 P0198 Oil temperature sensor-G8: the signal level is too high
16584 P0200 Injectors: failure in the electric circuit
16585 P0201 Injector 1-N30: a failure in the electrical circuit
igor2009 is offline   Reply With Quote
