Merge normal, trage binisor in oras (a scazut putin puterea motorului in ultima vreme, chiar si la viteze mici), dar la drum trage pana pe la 140 km/h, dupa care ramane fara putere, abia mai merge 90-100 cu pedala la podea. Fum nu scoate, consumul e normal, in bord nu e aprins decat ESP-ul. Daca e oprita si pornita din nou, trage iar pana la 140, si iar se limiteaza.
Am facut azi o diagnoza, dupa ce a primit talpa si intrat in sistemul de protectie sau ce-o fi limitarea asta.
Astept sa va dati cu parerea
Saturday,15,March,2014,17:04:53:21461
VCDS Version: Release 805.0
Data version: 20080529
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 274640km/170653miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 M
Component: 1,9l R4 EDC 0000SG 2813
Coding: 00002
Shop #: WSC 01317
3 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019458
Shop #: WSC 01317 785 00200
1 Fault Found:
01423 - Lateral Acceleration Sensor (G200)
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 01317
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 805 E
Component: KOMBI+WEGFAHRS. BOO V07
Coding: 01112
Shop #: WSC 00000
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0A3256921
Ident.-Nr. WEGFAHRS.:VWZ6Z0A3256921
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
64-10 - Not Currently Testable - Intermittent
01176 - Key
07-10 - Signal too Low - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 2H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
Part No: 1J1959801C
Component: 2H Tőrsteuerger. FS0002r
Part No: 1J1959802D
Component: 2H Tőrsteuerger. BF0002r
Part No: 1J4959811C
Component: 2H Tőrsteuerger. HL0002r
Part No: 1J4959812C
Component: 2H Tőrsteuerger. HR0002r
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
00931 - Locking Module for Central Locking; Rear Right (F223)
27-10 - Implausible Signal - Intermittent
End ---------------------------------------------------------------------
