Old 05-02-14, 11:00   #1
Dan bv
[CHEVROLET]
Default Resetare modul airbag
Pe tester imi iese ca trebuie schimbat modulul, nici codurile de eroare nu merg sterse. E vorba de un Chevrolet Lacetti din 2006.
Am gasit pe net o procedura de resetare dar nu ma incumet daca nu am certitudinea ca a probat-o cineva. E vorba de urmatorii pasi:
1. Open the fuse panel cover in the driver's side footwell by pulling down on it by hand.
2. Locate the yellow connector plugged into the fuse panel. This is the SRS power connector.
3. Pull the connector out of the fuse panel.
4. Unbend a paper clip and insert one end into each of the terminals on the end of the SRS plug.
5. Turn the ignition to the "On" position but do not start the vehicle.The two terminals on the airbag power connector will be connected via the paper clip. When power is supplied to the connected terminals ("jumping the terminals"), the airbag light will reset. The voltage is low enough that you don't need to be worried about an electrical shock.
6. Reconnect the SRS power connector to the fuse panel.
E ok procedura, a folosit-o cineva sau ma pot trezi ca imi sar airbagurile? (putin probabil atata timp cat modulul are erori/probleme)
Dan bv is offline   Reply With Quote
Old 06-02-14, 08:57   #2
Dan bv
[CHEVROLET]
Default Re: Resetare modul airbag
Am rezolvat-o dar nu prin metoda de mai sus, pe care nu am incercat-o. S-a rescris un "bin" si acum totul e ok.
